How to automate repetitive model simulation?
for Excel®
, API, Parameters, Variables, & Functions Version 5.6 1 Reply
Hello, I would like to automate repetitive evaluation (parameter change, mesh build, parameter sweep, derive values) using java. I would also like to automatically send the data from the derived current values to an Excel spreadsheet. The model has already been built. Can someone please recommend me tutorials on how to do so? Thank you.
1 Reply Last Post 09.07.2021, 05:04 GMT-4
Posted: 4 years ago 09.07.2021, 05:04 GMT-4
The manuals "Introduction to Application Builder" and "Application Builder Reference Manual" are great. These manuials show you how to use Java from within of Comsol. If you want to use Java in your own programs (outside of Comsol) then there is an example in the "Programming Referene Manual" in the chapter called "Graphical User Interfaces".
If you wish to save information in an Excel file you need to have LiveLink for Excel. If you have this LiveLink you can even write your code in VBA and interface to Comsol using all of the Comsol API.
Lars Gregersen
Comsol Denmark
Hi The manuals "Introduction to Application Builder" and "Application Builder Reference Manual" are great. These manuials show you how to use Java from within of Comsol. If you want to use Java in your own programs (outside of Comsol) then there is an example in the "Programming Referene Manual" in the chapter called "Graphical User Interfaces". If you wish to save information in an Excel file you need to have LiveLink for Excel. If you have this LiveLink you can even write your code in VBA and interface to Comsol using all of the Comsol API.
