How to make animation
In the transient simulation, use the obtained solution to make an animation, how to make the physical quantity scale of the animation change along with the animation
1 Reply Last Post 05.07.2021, 20:20 GMT-4
Posted: 3 years ago 05.07.2021, 20:20 GMT-4
The scales of plotted quantities in animations can be set by the separately-cited plots that are used in their creation; they will usually scale automatically if your individual plots do, but you have some additional control when you prepare the animation. Go to Results --> Export --> Animation, and select the Animation (it should be there, if you created it the usual way). Under Settings, scroll down to Advanced, and there you will find a checkbox that says "Synchronize scales between frames." You may want to set (or unset) that check-box. I hope that accomplishes your objective.
