Robert Koslover
Certified Consultant
03.06.2012, 23:17 GMT-4
I opened and ran your model with version 4.3.
1. The run appears to have been successful, in the sense that it executes and computes electric potentials and fields that appear to be in accordance with the boundary conditions that you specified.
2. That said, your geometry setup of the problem could use some improvement. First of all, your problem volume should likely extend well beyond both your probe and plate (assuming that both your probe and plate are intended to be finite). But you have put both the probe and plate right up against the problem boundaries, which is not a good way to allow the fields to relax to their correct orientations there.
04.06.2012, 04:39 GMT-4
Oh, I see.
Thank you for your guidance. Let me ask you another questions.
1) What is the difference between ploting (in volume) es.Ex+es.Ey+es.Ez vs. sqrt(es.Ex*es.Ex+es.Ey*es.Ey+es.Ez*es.Ez)
2) Is it possible in a volume-plot select a plane and represent it in a 2D-plot only (example: xy-plane when z=1)
Thank you in advance.
Oh, I see.
04.06.2012, 04:57 GMT-4
E is a vector, if you sum the three spatial components as scalars, or if you take the norm (sqrt(x^2+y^2+z^2) you will get different results
You can use the Data-Set (right click) "cut plane" to define a sub-solution set with the results interpolated to your cut plane, then you apply a 2D plot on that cut plane
04.06.2012, 05:28 GMT-4
So lets say that I aim to plot the Electric field in a certain volume. How I should plot:
a) es.Ex+es.Ey+es.Ez
b) sqrt(es.Ex*es.Ex+es.Ey*es.Ey+es.Ez*es.Ez)
c) sqrt(es.Ex*es.Ex+es.Ey*es.Ey+es.Ez*es.Ez) and add arrows according to es.Ex+es.Ey+es.Ez
Best regards
Best regards
04.06.2012, 05:59 GMT-4
a) I do not understand, perhaps you mean the vector (Ex,Ey,Ez) ?
b) has already a name by COMSOL es.normE
c) is the default volumic arrow setting
I have made up a quick example hereby, but I'm not sure I catch all your desire ;)
note that the arrow plot is not possible on a Data Set Surface = existing boundary, but OK on a free surface = Cut Plane
11.10.2012, 10:21 GMT-4
I am following this discussion. I have similar senario..but I would like have a different physics rather than electrostatics.
Bcause I want to set both plate (domain - not the boundaries) to an alternating potential at high frquency such as 20MHz.
anyone has any idea?
Kind regards,
Nada Manivannan
Kind regards,
Nada Manivannan
11.10.2012, 10:34 GMT-4
check the doc abour ACDC nad RF frequency "assumptions" and choose your physics accordingly, by comparing the model geometrical size and your wavelength size
12.10.2012, 04:52 GMT-4
Hi Tiago
I had a similar problem recently. I summarized my approach in this post. Maybe it helps you.
www.comsol.com/community/forums/general/thread/31204/
Martin
Hi Tiago
http://www.comsol.com/community/forums/general/thread/31204/
Martin
