Jeff Hiller
COMSOL Employee
4 years ago
04.06.2021, 16:16 MESZ
Hi Omar,
If a device has a low resistance, applying a 12V voltage drop to it can cause large current densities and therefore a high heat source.
In addition to that, if the boundary conditions or other temperature-limiting mechanisms are such that the device cannot cool efficiently, even a modest heat source can cause the temperature to rise a lot.
So, I would recommend you look at what the resistance of the device is and how realistic your modeling of the thermal BCs is.
Jeff Hiller
Hi Omar,
4 years ago
05.06.2021, 00:20 MESZ
Updated:
4 years ago
05.06.2021, 10:52 MESZ
Hi Jeff,
Thanks for your reply and help!
I am using Nichrome as a wire of the electrical heater (Material properties are Add-In from Comsol material properties) and the BC of the thermal BC's is only convection at the all sides (hair=5 w/m2.K and T=25 degC) and still the Temp is 10^4~5. However in real life application (nichrome wires and MgO outline) the heater required approx. V=12.6V and I=3.2A and the resistivity is 4ohm and the maximum Temperature reached is 350 degC with insulator on the boundary. So how can I simulate this heater (with the exact geometry) to get solution close to the real life application without changing the material.
Thank you for your considreation!
Omar
Hi Jeff,
Omar
Lars Gregersen
COMSOL Employee
4 years ago
07.06.2021, 08:46 MESZ
The resistance is not constant. When the temperature increases the resistance increases as well (for metals). You need to include that effect in your model.
Lars Gregersen
Comsol Denmark
