Put variables to the size
I want to ask something to try to solve optimization problem(size of the shape),
For example, if there is block shape, put (Width, Depth, Height)=(5, x, 5).
And with the MATLAB or any method , I want to give function to variable like 'linspace'.
It always makes errors, so, I want to check it is possible.
If it is impossible, do you have any idea to solve my problem??
Jinhoon Wang
1 Reply Last Post 29.05.2012, 04:19 GMT-4
Posted: 1 decade ago 29.05.2012, 04:19 GMT-4
first you should not use one letter names for "user" varibles, x.y.z and most others are already used by COMSOL
Then for geometries, currently you acn only define PARAMETERS and use these. A pARAMETER can be changed by a pstudy Parametric SWEEP condition (and only this node will remake your geometry)
Hi first you should not use one letter names for "user" varibles, x.y.z and most others are already used by COMSOL Then for geometries, currently you acn only define PARAMETERS and use these. A pARAMETER can be changed by a pstudy Parametric SWEEP condition (and only this node will remake your geometry) -- Good luck Ivar
