Quick AC/DC Rotational Machinery Question
Hello everyone
I am working on understanding how to use the rotary machinery physics in the AC/DC module using the 2d generator in the model library. I have changed the rotors to just be iron and made the coils have different phases, using Imax=sqrt(2)*10 [A] and changing the current in the multi-turn coil domain to Imax*exp(i*0) for one phase, Imax*exp(i*(2*pi)/3) for second phase and Imax*exp(i*(4*pi)/3) for the third phase.
I then run the simulation but it does not work. If I change the coils to an ampere's law with cylindrical coordinates with a radial remenent magnetic field and run the simulation then the rotor turns and it works. But if I use the different phases it errors out saying it has done too many steps. It seems I cannot have a changing phase in the stator while the rotor is rotating, which is what I want to do.
Does anyone have any ideas as to how I can make the stator coils have 3-phases while the rotor, with no magnetic fields just iron, rotates inside the stator?
Thanks.
Stephen
1 Reply Last Post 28.05.2012, 05:23 GMT-4
Posted: 1 decade ago 28.05.2012, 05:23 GMT-4
indeed it should work, in MEF you see nicely the phasor effect in these two models, so it should be there in RMM too
Hi indeed it should work, in MEF you see nicely the phasor effect in these two models, so it should be there in RMM too -- Good luck Ivar
