4 years ago
03.05.2021, 13:07 GMT-4
You don't say how you are modeling the materials. However- if the the resin is modeled by an insulator- there will be zero current unless there is a continuous path through conductive objects between the electrodes.
As usual, it would be a good idea to post your (reduced-size) model.
sakman
Materials Science and Engineering
4 years ago
03.05.2021, 18:53 GMT-4
Updated:
4 years ago
03.05.2021, 18:55 GMT-4
I am running a stationary study, where I have assigned one face of the cube (representing the resin) as the terminal, and the opposing face of the cube as the ground. The silver nanoparticles and graphene nanoplatelets have both been assigned their respective materials with conductivities in the 10^3 S/m regime, and the resin encasing them has been assigned 10^-14 S/m. The initial potential is set to 1V. The study is being run with the iterative solver (@ 100 iterations). I have attached the reduced size model.
4 years ago
03.05.2021, 19:21 GMT-4
If the conductivity of the resin is 1e-14, and there are no continuous paths through the inclusions, then the right answer is zero current. Well, maybe 1e-14 A.
At these small dimensions, is tunneling or field emission expected? Neither of these are modeled in the ec module.
(By the way, your model doesn't build properly for me so I can't run it.)
