how to cut or trim a parametric curve ?
I'm trying to make a 3D coil using parametric curve and sweep, but I need to cut a part of my curve, I can't change it by equation, so i just need to cut a part of it. In solidworks we used to do this by trim. Any Idea how can i do the same in COMSOL.
Indeed is there any changes or difference in results, when we do 2D modelling on MEF module for coil design with 3D modelling?
Thanks in Advance
3 Replies Last Post 22.11.2012, 01:00 GMT-5
Posted: 1 decade ago 17.05.2012, 12:53 GMT-4
We could use expressions like (parametric curve equation)*(x<3)*(y<2) or something similar. Please look at the reply by Ivar on the recent post ' finding a flow rate on a specified 3d cut plane'.
If it doesn;t help, post back with more details about your problem.
Good luck.
Posted: 1 decade ago 21.05.2012, 11:51 GMT-4
Thank you Mranal
Thank you Mranal
Muhammad Mohsin Rehman
Posted: 1 decade ago 22.11.2012, 01:00 GMT-5
Hi Guys,
I am using COMSOL 4.0a and need to define a 3 D coil in it. Can you please help me, if the issue has been resolved by now.
Thanks in advance.
Hi Guys, I am using COMSOL 4.0a and need to define a 3 D coil in it. Can you please help me, if the issue has been resolved by now. Thanks in advance.
