Robert Koslover
Certified Consultant
4 years ago
12.04.2021, 19:55 GMT-4
I only took a brief look at your model, but the first clue I noticed was that you have parameterized the geometry. Your specified parameters under global definitions of r_disc_1 etc. are different than the ones in the parametric sweeps. This can be ok, but it can also cause trouble. In your case, it is causing trouble, modifying the geometry to cause your boundary conditions to be improperly defined. If you make it so they don't change, your problem goes away!
I only took a brief look at your model, but the first clue I noticed was that you have *parameterized the geometry*. Your specified parameters under global definitions of r_disc_1 etc. are *different* than the ones in the parametric sweeps. This can be ok, but it can also cause trouble. In your case, it is causing trouble, modifying the geometry to cause your boundary conditions to be improperly defined. If you make it so they don't change, your problem goes away!
4 years ago
13.04.2021, 19:51 GMT-4
Updated:
4 years ago
14.04.2021, 04:51 GMT-4
Thanks so much Robert! If I am understanding you correctly, the issue is stemming from the geometry changing upon running a sweep?
Unfortunately I am hoping to loop through various (~200) radii combinations using the parametric sweep function (I set everything to 10mm just as a demonstration), and was wondering if you would have suggestions for how to achieve this?
