Robert Koslover
Certified Consultant
4 years ago
05.04.2021, 10:44 GMT-4
I don't claim to understand your problem, but it sounds like maybe you want to access, dynamically during the time-domain computations, the value of a quantity that has been computed at a different (earlier) time in the model? If that is what you are saying, then you may find it useful to take a look at Comsol's "withsol" operator. See the help system for more about that. If that is not what you are asking about, then... nevermind.
I don't claim to understand your problem, but it sounds like *maybe* you want to access, dynamically during the time-domain computations, the value of a quantity that has been computed at a different (earlier) time in the model? If that is what you are saying, then you may find it useful to take a look at Comsol's "**withsol**" operator. See the help system for more about that. If that is not what you are asking about, then... nevermind.
4 years ago
05.04.2021, 12:15 GMT-4
Updated:
4 years ago
05.04.2021, 12:16 GMT-4
Thanks for your reply Sir. I just wanted to know how to troubleshoot the error "Time Derivative Only Allowed With Respect To Mesh Time". I read a few replies on the discussion forum mentioning about conversion of d(XXX,t) to d(XXX,TIME) (i.e. conversion from time derivative toderivative w.rt. mesh time). None of the replies specified how exactly the above conversion can be done. Any help regarding the same would be helpful.
Edgar J. Kaiser
4 years ago
05.04.2021, 12:40 GMT-4
I guess you opened a model from an older version in 5.5. In case you are using expressions like d(xxx, t) in your own settings just replace t by TIME.
Otherwise check the equation view of the physics nodes for something like d(xxx, t) and replace t by TIME as well.
You may need to activate equation view in the preferences.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
4 years ago
06.04.2021, 13:16 GMT-4
Hi Edgar,
Thank you very much. It worked.
Hi Edgar,
