Eddy current losses in variable reluctance machine
Posted 09.05.2012, 14:00 GMT-4 Version 4.2a 1 Reply
I am modeling a variable reluctance machine where a magnetic field is generated by the stator windings and the rotor rotates in order to minimize the relucatance of the magnetic circuits. I am using the magnetic fields interface in a static study.
If possible I would like to calculate eddy current losses in the motor core, how do I model these correctly? Or should I just use apply some B^2*f^2 to my resulting dataset and integrate wrt time? Is it sufficient to apply a Lorentz velocity term to the rotating regions? That won't take care of the eddy current losses in the stator?
How about hysteresis losses, as I've understood it Comsol does not support this feature? Again, would it be a useful to apply a function like C*B^2*f to your solution data set and then integrate? How do you do that?
Thank you for your help.
Best Regards,
Mike
Best Regards,
Mike
1 Reply Last Post 09.05.2012, 15:13 GMT-4
