changes in interpolation function values
Pavan Kumar Penumakala
Hello all..
i just defined some values under t and f(t) columns in the interpolation function...
i have 800 values under the column t and f(t)
i want to do
f(t)=f(t)+200
how to read f(t) values and use them to assign for other variables
i tried but failed to get ..
thanks in advance
4 Replies Last Post 03.05.2012, 11:27 GMT-4
Posted: 1 decade ago 03.05.2012, 06:00 GMT-4
have you tried to define an analytial function (an1() or whatever) with argument "t" and expression f(t)+200 and then ?call an1()
Hi have you tried to define an analytial function (an1() or whatever) with argument "t" and expression f(t)+200 and then ?call an1() -- Good luck Ivar
Posted: 1 decade ago 03.05.2012, 10:15 GMT-4
dear sir..
i have the interpolation function with t and f(t) defiened..
t f(t)
1 200.666
2 100..78
300 24.55
now i have to add 200 to each value of f(t)...
t f(t)
1 200.676+200
2 100+200
i tried wid analytical functions..but failed again
dear sir.. i have the interpolation function with t and f(t) defiened.. t f(t) 1 200.666 2 100..78 ... .. .. 300 24.55 now i have to add 200 to each value of f(t)... t f(t) 1 200.676+200 2 100+200 .. . i tried wid analytical functions..but failed again
Posted: 1 decade ago 03.05.2012, 10:43 GMT-4
that has to work, I use it regularly.
So I assume you have another typo wrong somewhere, but its impossble for us to understand what it could be just like that ;)
Hi that has to work, I use it regularly. So I assume you have another typo wrong somewhere, but its impossble for us to understand what it could be just like that ;) -- Good luck Ivar
Posted: 1 decade ago 03.05.2012, 11:27 GMT-4
thanks for the reply..
i solved it ..
i use the wrong definitions..its my mistake
thanks
thanks for the reply.. i solved it .. i use the wrong definitions..its my mistake thanks
