24.04.2012, 07:49 GMT-4
in 2D, or 3D check the "Layers" tab in the geometry nodes, and take a look at the corresponding help file ;)
24.04.2012, 09:39 GMT-4
Marcus,
build the geometry from outside to inside:
1. Define the outer circle for the pipe
2. Define the inner circle for the pipe
3. Subtract inner from outer
4. Define the cylinder inside the pipe
This should give you the domains you want.
Cheers
Edgar
Marcus,
Cheers
Edgar
24.04.2012, 09:57 GMT-4
Marcus,
Cheers
Edgar
Sincerly, this will not build the geometry I want to build as shown on the attached drawing.
@Ivar Kjelberg
There is no "Layers" tab in the geometry node.
[QUOTE]
Marcus,
Cheers
Edgar
[/QUOTE]
@Ivar Kjelberg
24.04.2012, 10:24 GMT-4
Excuse me. I've found the layer tab and I could solve the problem. Thank you very much.
