Estimation of area defined by a condition
Hi all,
I would like to estimate an area based on a condition: ( for exampled the cumulative area on where the stress exceeds the strength ? Does anyone has clues on how to do it in Comsol 5.5 ?
Thank you in advance.
2 Replies Last Post 02.02.2021, 08:52 GMT-5
Posted: 3 years ago 02.02.2021, 08:50 GMT-5
Updated: 3 years ago 02.02.2021, 08:52 GMT-5
Hello Sarab,
You can use the integration tool available under Derived Values to integrate the boolean expression of your choice, for instance if you integrate T>300 it will return the volume where the temperature is greater than 300, etc.
Jeff Hiller
Hello Sarab, You can use the integration tool available under Derived Values to integrate the boolean expression of your choice, for instance if you integrate T>300 it will return the volume where the temperature is greater than 300, etc. Best, Jeff
Magnus Ringh COMSOL Employee
Posted: 3 years ago 02.02.2021, 08:52 GMT-5
Yes, in Surface Integration node under Results>Derived Values, for example, if you enter an expression such as
solid.mises>0.25[MPa]
It will evaluate to 1 where it's true (that is, the effective von Mises stress is above 0.25 MPa) and 0 everywhere else, so the surface area of that integration will be the area where the condition is true.
Hi, Yes, in **Surface Integration** node under **Results>Derived Values**, for example, if you enter an expression such as ``solid.mises>0.25[MPa]`` It will evaluate to 1 where it's true (that is, the effective von Mises stress is above 0.25 MPa) and 0 everywhere else, so the surface area of that integration will be the area where the condition is true.
