defining a variable
I want to investigate transmission from simply metal to air interface. If i need to define transmission in variables, then how can i define it in term of power? as value of power already defined in port boundary condition (Pin). Or is there any other method for this ?
Looking for helpful suggestions/comments.
Thanks in advance,
1 Reply Last Post 08.01.2021, 22:09 GMT-5
Posted: 4 years ago 08.01.2021, 22:09 GMT-5
Updated: 4 years ago 08.01.2021, 22:10 GMT-5
Ports are only some of the many ways to manage/analyze power inputs and outputs. You can define probes, coupling variables, and can execute post-processing integrations as well, among other possibilities. You can integrate power densities over surfaces to compute powers. You can integrate the normal-to-the-surface component of a power density vector over a surface, to compute the power flow through it. For example, if using probes, go to the Model Builder and right-click on "Definitions" under Component 1, and choose Probes --> Boundary Probe. Then in the Settings panel, change Type from Average to Integral. Choose the surface of interest to you, then put the appropriate power density expression in the "Expression:" box. As another example, on the post-processing side, Right-click "Derived Values" under the Results heading. Then choose Integration --> Surface Integration. The rest is pretty similar to before. Notice also the "Evaluate" button right near the top of the Settings/Surface Integration panel. You can also set up integration operators under Definitions --> Nonlocal Couplings --> Integration. If you experiment with these things, and read more about them in the Help system, you'll eventually figure out what works best for you in your particular circumstances. Good luck.
Ports are only *some* of the *many* ways to manage/analyze power inputs and outputs. You can define probes, coupling variables, and can execute post-processing integrations as well, among other possibilities. You can integrate power densities over surfaces to compute powers. You can integrate the normal-to-the-surface component of a power density vector over a surface, to compute the power flow through it. For example, if using probes, go to the Model Builder and right-click on "Definitions" under Component 1, and choose Probes --> Boundary Probe. Then in the Settings panel, change Type from Average to Integral. Choose the surface of interest to you, then put the appropriate power density expression in the "Expression:" box. As another example, on the post-processing side, Right-click "Derived Values" under the Results heading. Then choose Integration --> Surface Integration. The rest is pretty similar to before. Notice also the "Evaluate" button right near the top of the Settings/Surface Integration panel. You can also set up integration operators under Definitions --> Nonlocal Couplings --> Integration. If you experiment with these things, and read more about them in the Help system, you'll eventually figure out what works best for you in your particular circumstances. Good luck.
