Comsol with 2 CPU instead of using GPU
Hi! I am awared that comsol does not support GPU acceleration as stated before: https://www.comsol.com/forum/thread/250801/gpu-support?last=2020-02-03T13:32:52Z
However, I am planning to acquire a new PC with two Intel Xeon CPU instead of one with GPU to perform CFD simulations. My question is if I am going to be able to take full advantage of these two CPU when using Comsol or if it is not possible to do so.
What are your recomendations?
Greetings.
2 Replies Last Post 26.10.2020, 23:18 GMT-4
Posted: 5 years ago 26.10.2020, 10:03 GMT-4
Hello Eddy,
Yes, you will. All license types can take advantage of multiple CPUs on the same machine (shared memory parallelism). Only network licenses can take advantage of clusters (distributed memory parallelism).
Jeff Hiller
Hello Eddy, Yes, you will. All license types can take advantage of multiple CPUs on the same machine (shared memory parallelism). Only network licenses can take advantage of clusters (distributed memory parallelism). Best, Jeff
Posted: 5 years ago 26.10.2020, 23:18 GMT-4
Hello Eddy,
Thank you very much Jeff :D
>Hello Eddy, > >Yes, you will. All license types can take advantage of multiple CPUs on the same machine (shared memory parallelism). Only network licenses can take advantage of clusters (distributed memory parallelism). > >Best, > >Jeff Thank you very much Jeff :D
