How to use custom material properties in physics settings and results?
Posted 17.03.2012, 11:34 GMT-4 Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization Version 4.2a 0 Replies
My aim is to build a template for moisture transport. For that purpose I want to specify and use custom material properties, like moisture storage function and water vapor diffusion resistance factor in my models.
If I specify a constant local variable, for example M0 = 1, into material's Basic-properties, I can access that material property everywhere in the model with expression: material.def.M0.
However, if the local variable is coupled to any function it is not accessible anymore.
I know that I could create functions to Global Definitions or Model Definitions, but then I need to add for each material separate node into the physics. The advantage of using the material properties would be that I could have only one node and recycle the material properties by saving the material to material library.
Do you know is this possible?
Best Regards,
Sakari Lukkarinen
Hello Sakari Lukkarinen
