pulse
Dear Sir
i want to apply voltage source in the form of pulse train with ampliude 13kV
and freq.1000 Hz on cable termination to see its effect on temperature
after 40min. I can not solve it by time dependent solver , itl will take horriable time!
what can i do?
2 Replies Last Post 13.03.2012, 12:42 GMT-4
Posted: 1 decade ago 13.03.2012, 09:09 GMT-4
You could try to determine the heat flow at the terminal in a stationary model and use this result in a time dependent heat exchange model that doesn't need to resolve the AC waveform.
Cheers
Edgar
You could try to determine the heat flow at the terminal in a stationary model and use this result in a time dependent heat exchange model that doesn't need to resolve the AC waveform. Cheers Edgar
Posted: 1 decade ago 13.03.2012, 12:42 GMT-4
Dear Sir
could you please , give me some detetails about that solution. how i can get the heat flow?
Dear Sir could you please , give me some detetails about that solution. how i can get the heat flow?
