5 years ago
16.09.2020, 07:36 GMT-4
Updated:
5 years ago
There are two ways of running sweeps with multiple parameters:
- All combinations ; then parameter list for each parameter can have different lengths N1, N2, N3, ... because all N1 × N2 × N3 × ... cases will be computed
- Specified combinations ; then all parameter lists must be of equal length N, because only N combinations will be computed, using the 1st value of each list, then the 2nd, etc. until the N-th
You must have set the sweep type as "Specified combinations" and your parameter lists have different lengths. So depending on what you want you should switch to "All combinations" or equalize the lists' lengths.
* All combinations ; then parameter list for each parameter can have different lengths N1, N2, N3, ... because all N1 × N2 × N3 × ... cases will be computed
* Specified combinations ; then all parameter lists must be of equal length N, because only N combinations will be computed, using the 1st value of each list, then the 2nd, etc. until the N-th
5 years ago
17.09.2020, 04:54 GMT-4
Thanks! For the quick answer!
