How to create a table in comsol
Hi, I simply want to create a table with some result which are based on data from a line graph. I have searched this forum without any luck. I understand that I can do "Add Plot Data to Export" and then from there just get the table but isn't their a way so that I can save a table directly in comsol and then export that table?
5 Replies Last Post 26.02.2021, 03:53 GMT-5
Posted: 5 years ago 08.09.2020, 07:11 GMT-4
This will be possible in the next major release (5.6).
Posted: 5 years ago 08.09.2020, 08:01 GMT-4
Thank you Gunnar!
Thank you Gunnar!
Posted: 4 years ago 25.02.2021, 05:18 GMT-5
This will be possible in the next major release (5.6). Hey, Im using the Version 5.6 now, and I cannot find this feature :/. I just see the feature table graph but when I try to plug in Data from a Cut Point 1D it is just doing nonsense. If this feature was added, can you tell me how to find/use it?
Posted: 4 years ago 25.02.2021, 07:35 GMT-5
Updated: 4 years ago 25.02.2021, 07:35 GMT-5
Try the following:
  • Select the plot in the Model Builder.
  • Right-click and select "Copy Plot Data to Table" from the context menu.
This works for all 1D plot types.
Try the following: * Select the plot in the Model Builder. * Right-click and select "Copy Plot Data to Table" from the context menu. This works for all 1D plot types.
Posted: 4 years ago 26.02.2021, 03:53 GMT-5
Thank You! :)
Thank You! :)
