Dielectric heating between parallel plate electrodes
Hello all, I'm fairly new to Comsol. What I'm trying to do is model the heating of a dielectric in between two parallel plate electrodes at a frequency of 27.12 MHz. I would appreciate any suggestion as to which physics to use. Thanks in advance.
19 Replies Last Post 20.01.2016, 09:45 GMT-5
Posted: 1 decade ago 26.03.2012, 04:36 GMT-4
You can search for some papers for references. The electric currents and heat transfer are combined for this problem.
Posted: 1 decade ago 26.03.2012, 04:51 GMT-4
Jianhui,
Thank you for your response. Do you know of any tutorials by any chance?
Jianhui, Thank you for your response. Do you know of any tutorials by any chance?
Posted: 1 decade ago 16.04.2012, 00:38 GMT-4
You may need to try "Joule heating" model, which is just a combination of electric current and heat transfer.
Posted: 1 decade ago 16.04.2012, 02:31 GMT-4
Yang, thank you for your message. I will try that.
Posted: 1 decade ago 16.04.2012, 03:27 GMT-4
Hallo, did you solve your problem? I have the same. Is it diathermy heating, isn´t it? I don´t know how to bring AC (27.12MHZ) to the plate capacitor.
Lucie
Hallo, did you solve your problem? I have the same. Is it diathermy heating, isn´t it? I don´t know how to bring AC (27.12MHZ) to the plate capacitor. Lucie
Posted: 1 decade ago 16.04.2012, 03:37 GMT-4
Hello Lucie,
Not yet. My problem is actually RF heating of food placed between two plates. I will share with you in case I have any progress. In the mean time, good luck.
Hello Lucie, Not yet. My problem is actually RF heating of food placed between two plates. I will share with you in case I have any progress. In the mean time, good luck.
Posted: 1 decade ago 17.04.2012, 13:23 GMT-4
Dear Koray,
maybe I find a solution. I used AC/DC - Electric current and Heat Trensfer - Bioheat. I modeled two plates (cooper) - the first I signed as Boundary Current Source - enter value of Surface current source, the second plate is ground. Then I used frequecny domain study step with frequency 27.12MHz. Between plates I have knee with appropriate material properties. In Bioheat you have to mark a biological tissue and Heat souce.
Maybe it could help you.
With regards Lucie
Dear Koray, maybe I find a solution. I used AC/DC - Electric current and Heat Trensfer - Bioheat. I modeled two plates (cooper) - the first I signed as Boundary Current Source - enter value of Surface current source, the second plate is ground. Then I used frequecny domain study step with frequency 27.12MHz. Between plates I have knee with appropriate material properties. In Bioheat you have to mark a biological tissue and Heat souce. Maybe it could help you. With regards Lucie
Posted: 1 decade ago 17.04.2012, 16:27 GMT-4
Dear Lucie, thank you for your message. This definitely gives some ideas. How did your results look like? Did you get a resaonable temperature increase etc.?
Posted: 1 decade ago 18.04.2012, 03:13 GMT-4
Hi Koray,
for heat transfer I used time dependent study type and after 10 minutes of application is temperature incerase something about 1.5degC (with surface current source 100A/m^2). It is ok for diathermy heating. It will change with the distance of electrodes.
Hi Koray, for heat transfer I used time dependent study type and after 10 minutes of application is temperature incerase something about 1.5degC (with surface current source 100A/m^2). It is ok for diathermy heating. It will change with the distance of electrodes.
Posted: 1 decade ago 24.04.2012, 23:32 GMT-4
Sorry, I do not have any tutorials. The modeling work by Washington State U in food engineering may help you.
Posted: 1 decade ago 24.04.2012, 23:33 GMT-4
Joule heating is different from RF heating.
Posted: 1 decade ago 24.04.2012, 23:34 GMT-4
You can renfer to the models in COMSOL.
Posted: 1 decade ago 08.05.2012, 17:09 GMT-4
It is different, but if you want to simulate the parallel plate capacitive heating, this is the only model you can use in COMSOL. The RF module can only be applied on microwave heating (with waveguide) case.
Posted: 1 decade ago 18.05.2012, 13:04 GMT-4
You need AC/DC module to simualte RF heating in parallel plate electrodes system.
Posted: 1 decade ago 18.05.2012, 15:52 GMT-4
Take care about the underlying hypothesis that are used for ACDC and RF: basically E field wavelength much larger respectively much smaller than the dimension of the model.
When in between, both are more or less as wrong or as bad
Check the doc
Hi Take care about the underlying hypothesis that are used for ACDC and RF: basically E field wavelength much larger respectively much smaller than the dimension of the model. When in between, both are more or less as wrong or as bad Check the doc -- Good luck Ivar
Posted: 1 decade ago 06.03.2013, 19:30 GMT-5
Hi all,
If you want to heat the workloads at the RF range or microwave frequency, I want to recommed you this book 'Enginners' handbook of industrial microwave heating'.
I think that 'Joule's heat' is not the dominant factor in this situation, dipolar heat will be the main sorce of heating.
I'm also interested in parallel plate heating such as as dielectrics which are put on conductors.
I want to share your ideas and thesis.
Thanks.
Hi all, If you want to heat the workloads at the RF range or microwave frequency, I want to recommed you this book 'Enginners' handbook of industrial microwave heating'. I think that 'Joule's heat' is not the dominant factor in this situation, dipolar heat will be the main sorce of heating. I'm also interested in parallel plate heating such as as dielectrics which are put on conductors. I want to share your ideas and thesis. Thanks.
Posted: 9 years ago 19.11.2015, 10:51 GMT-5
Just came on line and see the question of RF heating. I am sure I can help, I have been testing with RF for several years with a wide range of dielectric materials. If you are still looking at the question let me know.
Posted: 9 years ago 17.01.2016, 07:06 GMT-5
Hello David
I have the same problem mentioned in the topic. Which one is more efficient to simulate parallel plate RF heating? Ansys HFSS coupled with transient thermal analysis? or using COMSOL RF or AC/DC module? Some friends above have said that RF module is convenient for microwave heating. so I am a bit confused.
Thank you in advance
Hello David I have the same problem mentioned in the topic. Which one is more efficient to simulate parallel plate RF heating? Ansys HFSS coupled with transient thermal analysis? or using COMSOL RF or AC/DC module? Some friends above have said that RF module is convenient for microwave heating. so I am a bit confused. Thank you in advance
Walter Frei COMSOL Employee
Posted: 9 years ago 20.01.2016, 09:45 GMT-5
Regarding the topic of dielectric heating between parallel plate electrodes, you will find this article helpful:
www.comsol.com/blogs/study-radiofrequency-tissue-ablation-using-simulation/
as well as this example model of a parallel plate capacitor in the frequency domain:
www.comsol.com/model/frequency-domain-modeling-of-a-capacitor-12693
and also the Introduction to COMSOL Multiphysics, which shows how to couple an Electric Currents physics to Heat Transfer:
cdn.comsol.com/documentation/5.1.0.180/IntroductionToCOMSOLMultiphysics.pdf
Hello, Regarding the topic of dielectric heating between parallel plate electrodes, you will find this article helpful: http://www.comsol.com/blogs/study-radiofrequency-tissue-ablation-using-simulation/ as well as this example model of a parallel plate capacitor in the frequency domain: http://www.comsol.com/model/frequency-domain-modeling-of-a-capacitor-12693 and also the Introduction to COMSOL Multiphysics, which shows how to couple an Electric Currents physics to Heat Transfer: http://cdn.comsol.com/documentation/5.1.0.180/IntroductionToCOMSOLMultiphysics.pdf
