Comparing two 2D plots
When I want to compare two 2D plots of two different solutions performed sequencially, I export the first plot into a text file and import it after the second solutions is done. Then I compare them.
Is there a better way to compare two 2D plots of two different solutions performed in different times for the same model. Because my method is not a practical one.
Thank you.
5 Replies Last Post 05.09.2020, 04:12 GMT-4
Posted: 5 years ago 04.09.2020, 09:17 GMT-4
Hi Suad,
You can use the Join feature under the Results node to join two datasets and compare them in a single plot.
Cheers,
Alex
Hi Suad, You can use the Join feature under the Results node to join two datasets and compare them in a single plot. Cheers, Alex
Posted: 5 years ago 04.09.2020, 12:10 GMT-4
Thank you for your answer Alex,
I think I need two different solutions under Data Sets to use Join feature. But when I compute my model after changing some of my model's parameters, it always produce Study 1/Solution 1 (sol1), so the previous data is erased in this way. How can I sustain my solution or plot data after my second compute?
Thanks a lot.
Thank you for your answer Alex, I think I need two different solutions under Data Sets to use Join feature. But when I compute my model after changing some of my model's parameters, it always produce Study 1/Solution 1 (sol1), so the previous data is erased in this way. How can I sustain my solution or plot data after my second compute? Thanks a lot.
Posted: 5 years ago 04.09.2020, 14:23 GMT-4
Hi Suad,
Simply right click Solver1->Solution->Copy. This will create a copy of your current solution so that you can run another simulation without erasing your solution.
Cheers,
Alex
Hi Suad, Simply right click Solver1->Solution->Copy. This will create a copy of your current solution so that you can run another simulation without erasing your solution. Cheers, Alex
Posted: 5 years ago 05.09.2020, 03:50 GMT-4
Hi Alex,
When I carried out copy/paste or dublicate commands for a solution, its name (sol1) remains constant. Thus the next computation writes into copied solution as well as the new one. Then I have two solutions that they are identical.
Hi Alex, When I carried out copy/paste or dublicate commands for a solution, its name (sol1) remains constant. Thus the next computation writes into copied solution as well as the new one. Then I have two solutions that they are identical. Thanks
Posted: 5 years ago 05.09.2020, 04:12 GMT-4
Oh, I think I found the solution. It is enough to run "Create Solution Copy" under the study section. It creates a new copy of solution with a new name (solx).
Thanks a lot Alex.
Oh, I think I found the solution. It is enough to run "Create Solution Copy" under the study section. It creates a new copy of solution with a new name (solx). Thanks a lot Alex.
