Electric charge much lower than expected in plate capacitor
Hi there,
the charge I get from global evaluation is much lower than expected on my terminals.
My model is a bending beam, which should touch the bottom of a cavity by electrostatic attraction. I started off with electrostatics, but global evaluation of the terminal charge returns a 1E-9 smaller value.
Preliminary considerations are based on a plate capacitor ( Q = V * C ) with 30 V potential difference, 20 mm^2 plate area, 70 um plate distance and the relative permittivity is 80. This results in a charge of about 6.07 C. But global evaluation of the terminal charge returns 6.06E-9.
However, when I set the terminal constraints to charge, an electric field is not generated at all.
Any idea where I could be mistaken?
Thanks in advance,
Jonas
4 Replies Last Post 17.08.2020, 11:27 GMT-4
Posted: 5 years ago 17.08.2020, 08:11 GMT-4
Jonas,
the result of your hand calculation is much too high. The Comsol result is in the correct order of magnitude.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Jonas, the result of your hand calculation is much too high. The Comsol result is in the correct order of magnitude. Cheers Edgar
Posted: 5 years ago 17.08.2020, 08:30 GMT-4
Thanks for the quick response!
Can you explain, why that is the case?
Jonas
Thanks for the quick response! Can you explain, why that is the case? Jonas
Posted: 5 years ago 17.08.2020, 08:58 GMT-4
Just take the textbook formula for a plate capacitor.
Edgar J. Kaiser
www.emphys.com
Posted: 5 years ago 17.08.2020, 11:27 GMT-4
Whenever the NUMBER is right...but the order of magnitude is wrong...check the units.
(In fact, check the units anyway.)
Whenever the NUMBER is right...but the order of magnitude is wrong...check the units. (In fact, check the units anyway.)
