Magnus Ringh
COMSOL Employee
4 years ago
13.08.2020, 10:21 GMT-4
Hi Naresh,
You can use Boolean expressions using inequalities, such as
Q_sei*exp(a_sei/T[K]*(T>=400[K]&&T<500[K])+Q_n*exp(a_n/T[K])(a_sei/T[K]*(T>=500[K]&&T<530[K])+...
All those terms will be zero where and when the temperature is outside their limits and equal to the desired expression inside the desired temperature ranges. Here I assume that Q_sei, a_sei, etc. are defined as constants or variables. You should probably also add terms for temperatures outside of the range (above and below) 400 K to 620 K; otherwise, the heat source will be zero for those temperatures.
Magnus Ringh, COMSOL
Hi Naresh,
`Q_sei*exp(a_sei/T[K]*(T>=400[K]&&T=500[K]&&T
4 years ago
20.08.2020, 10:13 GMT-4
Dear Magnus,
Thank you so much,, this has solved the issue stated.
Dear Magnus,
4 years ago
25.08.2020, 05:02 GMT-4
Hi Naresh,
`Q_seiexp(a_sei/T[K](T>=400[K]&&T=500[K]&&T
Dear Magnus Ringh,
Could you please sort this out for me.
Theme: Heat transfer between bodies in a room filled with air
The initial temperature of one cell is 1000[K] and the others' are at room temperature. The temperature of other cells will increase due to heat conduction through air over time. As soon as the other cells reach 363[K], the temperature has to take a sudden jump to 1400[K]. No reactions, no heat sources. Just a simple jump of temperature is needed to check the heat wave propagation.
How can I achieve this?
Many thanks.
>Hi Naresh,
Dear Magnus Ringh,
Many thanks.
Magnus Ringh
COMSOL Employee
4 years ago
26.08.2020, 02:47 GMT-4
Updated:
4 years ago
26.08.2020, 09:50 GMT-4
Hi Naresh,
For this type of modeling questions, I suggest that you contact COMSOL's technical support. However, I think that a maximum nonlocal coupling operator, defined in domains away from the heater, would be useful for setting up a conditional expression to achieve what you want to simulate.
Hi Naresh,
