29.02.2012, 17:59 GMT-5
I just checked it and it works fine for me. I used PDE (c) and change order in PDE Settings - Discretization - Element Order. DoF increased from 1217 for quadratic to 4745 for quartic
01.03.2012, 13:21 GMT-5
Thankyou for your help.
I think you talking about comsol 3.5a. I tried in comsol 3.5a and it worked there as you said. But if I use latest version i.e. comsol 4.2 and change element order in Discretization - Element Order, it does not work. I dont know why?
Would be good if I am able to solve it using latest version of comsol as well.
Anyway thanks again.
Abid
Abid
02.03.2012, 15:11 GMT-5
Hellow again,
I solved eigenvalues problem using comsol3.5a. Now I want to export all eigenvalues but i could not do it. I exported the mesh by going through File-Export-Mesh to file.....but i dont see how to export all calculated eigenvalues.
Any one help me please.
Thanks in advance.
Hellow again,
Thanks in advance.
02.03.2012, 15:33 GMT-5
No, I was talking about 4.2a. It works for me. Probably you do something differently. Upload your model so I can have a look.
02.03.2012, 15:58 GMT-5
Hi Alexander,
Please have a look at files I am sending you both m.file and .mph files.
And also tell me about exporting calculated eigenvalues.
Thanks.
Hi Alexander,
Thanks.
02.03.2012, 16:57 GMT-5
Here are my results after changing discretization order:
Quadratic:
Number of degrees of freedom solved for: 93.
Solution time (Study 1): 1 s.
Quintic:
Number of degrees of freedom solved for: 531.
But I changed it in the different place. Next to the "Model Builder" on top there is "Show" button. Click it to bring the menu. There you select "Discretization". Then click on PDE (c) node and in "settings" you will see that new section called "Discretization" appeared. There you can change your element order.
And sorry, I can't help you with eigenvalues.
Quadratic:
Quintic:
05.03.2012, 14:43 GMT-5
Thankyou so much Alexander it worked now.
One more thing I wanted to make sure that comsol uses the isoparametric elements of same order for domain with curved boundaries. Do you know that comsol is realy doing this what i want?
Abid
Abid
05.03.2012, 19:24 GMT-5
I'm not sure what you are asking about. If it's about curvilinear elements, then I don't think COMSOL uses them.
