24.02.2012, 04:42 GMT-5
that is certainly an important domain where i would like to see more models described in COMSOL and by the users, I would say take a few of the simpler cases developped in F. Litvin's excellent books on Gear gemeotry and Theory, or even "non-circular gears" and run them through COMSOL.
But that rewuqires in Geometry Assembly mode : solid, contact and posibly lubricant thin film (CFD) physics and mix thereof, probably with quite some add on of home brewed equations.
but already the two first physics would be a good starting point
24.02.2012, 06:49 GMT-5
Dear Ivar
Thank you so much
I'll try to find these books.
I found in COMSOL that:
www.comsol.com/showroom/gallery/1431/
It's different not same with my research.
1.When you open that publication you'll understand my target.
ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20000120586_2000175882.pdf
I didn't change diameter, overall(total) length and loads of cylindrical roller.
2.but I invented and calculated the new profile, I would like to get results when changing crown Radius of cylindrical roller.
3. I want to show the invention, but I can't attache the novel profile of roller.
Thank you very much again for your advise
The Regards
[QUOTE]
[/QUOTE]
Dear Ivar
Thank you so much
I found in COMSOL that: http://www.comsol.com/showroom/gallery/1431/
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20000120586_2000175882.pdf
The Regards
24.02.2012, 08:25 GMT-5
indeed keep yor "confidential" knowledge far from any web site ;) Google and the others is already very intrusive I find.
Clearly you should start to study those simple cases in the model library, then add lubricant if required but that is another^power of something in complexity.
As mostly you might get complex surfaces for your profiles to tranasfer, check how to, CAD software or livelink or fully matlab generated in COMSOL. For orinary mechanics my SW livelink is perfect, I also know a local maufacturer is making special evolvere and crown gears with SW APIs so surface generations like that are possible, still to see how these are passed to COMSOL, but there you have the Parasolid kernel that should be common to both. I'm not sure how it goes with other CAD tools and COMSOL, probably very well, but gear shapes are specials, partiulrly in 3D, be aware and do your tests ;)
Probably the first of the books, is a good reference for you, the second is really more a eyewaker for very special gearings. Litvin is one of the reference for gears, from my knowledge
