Boundary layers mesh
Hello all,
My main question is related to "Boundary layers" in meshing for laminar flow physics?
As I understand, Boundary layers are needed when we got a high velocity gradient touching our moving surface. This is the case for turblent flow. But, for laminar flow, why do we need boundary layers in the mesh ?
Does the automatic generation of boundary layers by COMSOL mesher means that we need the these layers for our simulations or I could simply remove it from my mesh?
Thanks in advance
Mohamed
3 Replies Last Post 10.10.2012, 07:36 GMT-4
Posted: 1 decade ago 23.02.2012, 15:03 GMT-5
boundary layers are interesting along all boundaries across which you have strong gradients, particularly for diffusion type equations. Even in laminar flo, along a no-slip boundary you have a rather strong gradient of the velocity, ending at U=0 on the boundary. Therefore COMSOl always proposesby defult boundary layers, for the CFD on such no-slip (and perhaps many others haven checked all cases) boundaries. And this also in laminar flow.
Personally I use boundary layers also in HT transient analysis between material with very different heat diffusiviies, or along boundaries with constant T, where I have a very different initial condition in the material (again essentially for transient solver cases, far less critical for steady state solving))
Hi boundary layers are interesting along all boundaries across which you have strong gradients, particularly for diffusion type equations. Even in laminar flo, along a no-slip boundary you have a rather strong gradient of the velocity, ending at U=0 on the boundary. Therefore COMSOl always proposesby defult boundary layers, for the CFD on such no-slip (and perhaps many others haven checked all cases) boundaries. And this also in laminar flow. Personally I use boundary layers also in HT transient analysis between material with very different heat diffusiviies, or along boundaries with constant T, where I have a very different initial condition in the material (again essentially for transient solver cases, far less critical for steady state solving)) -- Good luck Ivar
Posted: 1 decade ago 10.10.2012, 05:57 GMT-4
Does anyone have any suggestions for joining a boundary layer mesh to a regular tetrahedral mesh. I have an acoustics model which contains a narrow pipe where the thermoacoustics model is implemented but is mostly free space. The boundary mesh seems sensible for modelling the interaction of fluid with a boundary layer but it won't mesh with the remaining space.
Alasdair
Does anyone have any suggestions for joining a boundary layer mesh to a regular tetrahedral mesh. I have an acoustics model which contains a narrow pipe where the thermoacoustics model is implemented but is mostly free space. The boundary mesh seems sensible for modelling the interaction of fluid with a boundary layer but it won't mesh with the remaining space. Alasdair
Posted: 1 decade ago 10.10.2012, 07:36 GMT-4
Often a boundary layer goes all the way out to the outer edge of your model (to the in-out-lets), if you need to continue the mesh from there for another physics, you might get around by using a mesh "convert" (to tri) on the in-out-let boundaries, or you might use assembly mode but that is rahter heavy to define all the pairs
Hi Often a boundary layer goes all the way out to the outer edge of your model (to the in-out-lets), if you need to continue the mesh from there for another physics, you might get around by using a mesh "convert" (to tri) on the in-out-let boundaries, or you might use assembly mode but that is rahter heavy to define all the pairs -- Good luck Ivar
