How to implement massless formulation in particle tracing
Posted 22.02.2012, 22:14 GMT-5 Charged Particle Tracing, Particle Tracing for Fluid Flow Version 4.3a 8 Replies
What is the boundary condition in this case?
Regarding the boundary condition , for drag force an additional drag force boundary condition is needed. What about boundary condition for mass-less?
I'm trying to use particle tracing in a static mixer to simulate a mixing between 2 gases.
When I set Newtonian as formulation and bounce as wall condition I correctly find the particle trajectories at the outlet (Particle tracing bounce.png attached).
In every way to use this formulation i have to set particles diameter and density, but in my case i don't have solid particles in the flow.
I think that should be more correct to use the massless formulation.
However when i try to do it the particles don't leave the inlet section as they have no velocity (Particle tracing massless.png attached).
What is wrong with my model?
Thank you in advance for your support.
Raffaella
Raffaella
The Particle Velocity is probably set to the default 0 values under the Particle Properties node. Set the velocity to u, v, w or whatever variable names you are using for the fluid-flow.
Nagi Elabbasi
Veryst Engineering
thank you for your reply. As you suggested the velocity was set to zero.
Using the velocity components the particles leave the inlet section but they stop as they arrive on the first element because the wall condition is set to freeze. (Image attached)
In the massless formulation i can not set the bounce condition.
Which kind of post processing do you suggest to highlight the particle paths from the inlet towards the outlet?
Thank you for the support.
Raffaella
Dear Raffaella,
Nagi Elabbasi
Veryst Engineering
What you probably need is a much smaller time step size for the particle tracing solver, not a bounce condition.
Nagi Elabbasi
Veryst Engineering
Suggested Content
- FORUM Particle Tracing for fluid flow and magnetic field
- BLOG What Formulation Should I Use for Particle Tracing in Fluids?
- FORUM Counting Particle Types at Outlet for Particle Tracing for Fluid Flow feature
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling? - FORUM Error in particle count for surface integration in particle tracing for fluid flow
