Full 3D Mesh Import with Topology Preservation
Dear all,
I need to import custom meshes into Comsol, and I have to write my output routine. The choice is now about what format I should output, so that Comsol will import it as it is.
A very strict requirement is that the topological information of the mesh must be conserved: I need to match tetrahedrons, vertices, and connectivity at all levels between different meshes. All the meshes I will produce have the same topology, and cannot be changed/remeshes.
What do you suggest I could output to ease the import? I've read in the forum about STEP, and I have also read about mphtxt, but I don't know if any format will be processed and I will lose information.
Thanks, Franco
3 Replies Last Post 11.06.2020, 10:31 GMT-4
Posted: 5 years ago 11.06.2020, 09:01 GMT-4
Hello Franco,
The COMSOLMultiphysics Mesh Import and Export Guide discusses the various formats available to you.
Jeff Hiller
Hello Franco, The [COMSOLMultiphysics Mesh Import and Export Guide](https://www.comsol.com/model/comsol-multiphysics-mesh-import-and-export-guide-72351) discusses the various formats available to you. Best regards, Jeff
Posted: 5 years ago 11.06.2020, 10:05 GMT-4
Hi Jeff,
thanks for the answer. I found the COMSOL_MeshImportExportGuide.pdf very helpful! Thank you!
I just have to be sure not to write the wrong format... In the PDF I see that
When importing volumetric mesh data, COMSOL Multiphysics can retain the original mesh, such as a tetrahedral mesh, and use the mesh data in any type of physics analysis, regardless of the intent of the original imported mesh.
The "can" is a little scary to me, as I do really need to make analyses on different meshes retaining the very same underlying topology.
So if I write a mphtxt file I will always retain in Comsol all vertices and cell indices, and connectivity?
I am sorry to ask such a pedantic question, but without a complete bijection between meshes the solutions won't make any sense...
Thank you very much! Franco
Hi Jeff, thanks for the answer. I found the COMSOL_MeshImportExportGuide.pdf very helpful! Thank you! I just have to be sure not to write the wrong format... In the PDF I see that > When importing volumetric mesh data, COMSOL Multiphysics can retain the original mesh, such as a tetrahedral mesh, and use the mesh data in any type of physics analysis, regardless of the intent of the original imported mesh. > The "can" is a little scary to me, as I do really need to make analyses on different meshes retaining the very same underlying topology. So if I write a `mphtxt` file I will always retain in Comsol all vertices and cell indices, and connectivity? I am sorry to ask such a pedantic question, but without a complete bijection between meshes the solutions won't make any sense... Thank you very much! Franco
Posted: 5 years ago 11.06.2020, 10:31 GMT-4
Updated: 5 years ago 11.06.2020, 10:41 GMT-4
Hi Franco,
If you import the mesh and then don't convert that mesh into a geometry that you then remesh, then yes, COMSOL will use the mesh you imported. I am not an expert on the topic so I can't guarantee you that the nodes and elements don't get renumbered.
BTW, you don't have to take my word for it: after a computation, you can export the mesh and nodal post-processing data out of COMSOL and double-check that it matches what you imported.
Jeff Hiller
Hi Franco, If you import the mesh and then don't convert that mesh into a geometry that you then remesh, then yes, COMSOL will use the mesh you imported. I am not an expert on the topic so I can't guarantee you that the nodes and elements don't get renumbered. BTW, you don't have to take my word for it: after a computation, you can export the mesh and nodal post-processing data out of COMSOL and double-check that it matches what you imported. Best regards, Jeff
