Problem in Boundary Integration
I am having some issues with the command POSTINT. I am tyring to solve a much more complex problem than outlined in the attached document. However, if somebody can point out what is the issue in the sample problem attched, I can go figure out the issue in my original problem.
3
|****del^u=0*********\ 4 (u=1)
| 1 (u=0) *************/
|**********************/ 5 (u=1)
2
I am solving Laplace's equation in the above 2D-domain where all the edges except 1,4 and 5 are insulated. Thus the current density (=-del(u)) when integrated over any boundary edge should give me the total current passing through the edge. I use:
% Current passing into the system through edges 4 and 5
v1 = postint(fem,'-(ux*(-nx)+uy*(-ny))','dl',[4,5],'edim',1)
% Current passing out of the system through edge 1
v2 = postint(fem,'-(ux*(nx)+uy*(ny))','dl',[1],'edim',1)
Since the edges 3 and 2 are insulated (i.e. del(u)=0), and the gometry is symmetric I should expect v1 = v2. But I get,
v1 = 0.8553
v2 = 0.8776
Why this discrepancy ? I have attached the code for your perusal and also the results.
Regards
Murali
4 Replies Last Post 08.08.2012, 01:01 GMT-4
Posted: 1 decade ago 16.02.2012, 02:30 GMT-5
have you checked how this difference changes with the mesh, some % difference in flux estimation is not necesarily surprising.
Check also the KB on the amin site about flux estimation
Hi have you checked how this difference changes with the mesh, some % difference in flux estimation is not necesarily surprising. Check also the KB on the amin site about flux estimation -- Good luck Ivar
Posted: 1 decade ago 16.02.2012, 18:57 GMT-5
Hi Ivar,
Yes I have checked the dependence on meshing. It is still the same. I did not quite understand what you meant by "KB" and "amin site" ? Can you please explain ?
Murali
Hi Ivar, Yes I have checked the dependence on meshing. It is still the same. I did not quite understand what you meant by "KB" and "amin site" ? Can you please explain ? Thanks Murali
Posted: 1 decade ago 17.02.2012, 02:42 GMT-5
I think the issues discussed in chapter "Computing Accurate Fluxes" of the Comsol (3.5a) User's Guide apply to your problem. You should be able to get much more precision in post-processing by "summing the reaction force" along the boundary rather than integrating the flux.
Posted: 1 decade ago 08.08.2012, 01:01 GMT-4
KB is the Knowledge Base of the "main" (typo sorry) COMSOL site.
see www.comsol.eu/support/knowledgebase/browse/900/
that is where you find most tricks directly commented from COMSOL
Hi KB is the Knowledge Base of the "main" (typo sorry) COMSOL site. see http://www.comsol.eu/support/knowledgebase/browse/900/ that is where you find most tricks directly commented from COMSOL -- Good luck Ivar
