How to load a group of sampling data as one parameter
Dear All,
I have an experimental data saved in text files. (Pressure Vs. Time, sampling data)
I want to load/read this file as my source and assign it to one of my boundary.
Now I am using transient acoustic structure interface and I can easily give my time data in the study settings(0,1/99998-1, 1-1/99998 - 99998 is data length and unit in second). However, the pressure data is not linear or having an equation. Is there any way to read my pressure data?
I am trying to load txt in parameter but it looks like impossible. It has to be an equation or one constant.
Thanks a lot in advance for any suggestions.
I appreciate it.
Best
Xu
2 Replies Last Post 15.02.2012, 18:07 GMT-5
Posted: 1 decade ago 15.02.2012, 16:42 GMT-5
I'm not sure it's what you exactly need, but try that:
In Model-Definitions create Functions-Interpolation. Then in Parameters choose Data Source:File and select your file.
This way you can define a function using your data file.
I'm not sure it's what you exactly need, but try that: In Model-Definitions create Functions-Interpolation. Then in Parameters choose Data Source:File and select your file. This way you can define a function using your data file.
Posted: 1 decade ago 15.02.2012, 18:07 GMT-5
Dear Alexander,
Thanks a lot for your reply.
I will try what you said and let you know.
I have a pressure data as a function of time.
However, the pressure can not be written in a equation format (like random data).
So I can not write my own equation in Comsol. I am trying to see if I can upload all sampling data and save as one pressure parameter..
Xu.
Dear Alexander, Thanks a lot for your reply. I will try what you said and let you know. I have a pressure data as a function of time. However, the pressure can not be written in a equation format (like random data). So I can not write my own equation in Comsol. I am trying to see if I can upload all sampling data and save as one pressure parameter.. Thanks Xu.
