how do I know if my license has live link to matlab
Would you please check my license and see if i have
5 Replies Last Post 19.12.2012, 01:29 GMT-5
Posted: 1 decade ago 15.02.2012, 12:32 GMT-5
in COMSOL go to Help-About COMSOL. Then select Licensed products and press Show Information
Posted: 1 decade ago 15.02.2012, 18:36 GMT-5
Thanks I got
Live Link Matlab
Used Licenses = 0
Total Licenses = 30
(I'm connected to the server of the school which has a particular license - is not personal)
What does it mean? So I have Live Link or I need to have Used Licenses=1 instead of 0. Thanks
[QUOTE] in COMSOL go to Help-About COMSOL. Then select Licensed products and press Show Information [/QUOTE] Thanks I got Live Link Matlab Used Licenses = 0 Total Licenses = 30 (I'm connected to the server of the school which has a particular license - is not personal) What does it mean? So I have Live Link or I need to have Used Licenses=1 instead of 0. Thanks
Posted: 1 decade ago 16.02.2012, 02:10 GMT-5
for me I read it as: you are not using the LiveLink licence, but it's available, so COMSOL is not started with matlab
Hi for me I read it as: you are not using the LiveLink licence, but it's available, so COMSOL is not started with matlab -- Good luck Ivar
Posted: 1 decade ago 18.12.2012, 20:44 GMT-5
Hi Ivar,
I have the same problem. I want to connect Matlab to Comsol 4.2a. I can create a Comsol model easy and save it as a .m file, but the Matlab program does not run it. I checked the license 0, , it says used= 0, available = 5. What do I have to do?
Fred
Hi Ivar, I have the same problem. I want to connect Matlab to Comsol 4.2a. I can create a Comsol model easy and save it as a .m file, but the Matlab program does not run it. I checked the license 0, , it says used= 0, available = 5. What do I have to do? Thanks Fred
Posted: 1 decade ago 19.12.2012, 01:29 GMT-5
you have install and run info in the manuals, and some tricks in the KB (knowledge Base on the main site, such as being sure you have registered your matlab as com server once, see the preferences)
If nothing else works, it's best to discuss with your sysadmin or ylour local COMSOL rep, for installation issues
Hi you have install and run info in the manuals, and some tricks in the KB (knowledge Base on the main site, such as being sure you have registered your matlab as com server once, see the preferences) If nothing else works, it's best to discuss with your sysadmin or ylour local COMSOL rep, for installation issues -- Good luck Ivar
