Partial differential operator
Hi,everyone! I have some question about partial differential operator. We know the ampere's law: J=curlH. So if we have a wire along Z axis, we have Jz=curl.Hz. In comsol Hyx means the x component of the gradient of Hy (is this sure? ), then we have curl.Hz=Hyx-Hxy. But in the result part, I make the expression to be : mfh.Jz-(Hyx-Hxy) , the output is not 0. What's wrong with it? In my opinion, Hyx doesn't mean the x component of the gradient of Hy, maybe it means the x component of the derivative of Hy. So, what's the partial differential operator in COMSOL?
Any suggestions you give will help me a lot.Thank you.
4 Replies Last Post 05.06.2020, 01:03 GMT-4
Posted: 5 years ago 03.06.2020, 14:53 GMT-4
Hi Ming,
The variable Hxy should indeed give the derivative of Hx with respect to y. Thus, the current density in the z direction should be Jz=Hyx-Hxy as you suggested. However, I am not sure why you are getting a non-zero value for the expression mentioned above. What kind of value are you getting for the expression? Also, are you using a moving mesh?
Cheers,
Alex
Hi Ming, The variable Hxy should indeed give the derivative of Hx with respect to y. Thus, the current density in the z direction should be Jz=Hyx-Hxy as you suggested. However, I am not sure why you are getting a non-zero value for the expression mentioned above. What kind of value are you getting for the expression? Also, are you using a moving mesh? Cheers, Alex
Posted: 5 years ago 03.06.2020, 21:18 GMT-4
Dear Alex,
Thank you for your suggestion.
Firetly, I just use a triangular mesh, it's not a moving mesh.
And, I use the mfh part. The expression: mfh.curlHz-mfh.Jz is zero, but the value of mfh.Jz-(Hyx-Hxy) is from -2.56e-13 to 2.34e-13.
Yours,
Ming
Dear Alex, Thank you for your suggestion. Firetly, I just use a triangular mesh, it's not a moving mesh. And, I use the mfh part. The expression: mfh.curlHz-mfh.Jz is zero, but the value of mfh.Jz-(Hyx-Hxy) is from -2.56e-13 to 2.34e-13. Yours, Ming
Posted: 5 years ago 04.06.2020, 09:25 GMT-4
Hi Ming,
This is probably due to numerical error rather than the definition of Hyx. Taking the derivative of the H field will lead to numerical error, and since the H field is usually on the order of 1e6 A/m, the error of 1e-13 seems reasonable. The reason why mfh.curlHz-mfh.Jz gives zero is that mfh.Jz is defined as mfh.curlHz, so Comsol recognizes that they are exactly equal.
Cheers,
Alex
Hi Ming, This is probably due to numerical error rather than the definition of Hyx. Taking the derivative of the H field will lead to numerical error, and since the H field is usually on the order of 1e6 A/m, the error of 1e-13 seems reasonable. The reason why mfh.curlHz-mfh.Jz gives zero is that mfh.Jz is defined as mfh.curlHz, so Comsol recognizes that they are exactly equal. Cheers, Alex
Posted: 5 years ago 05.06.2020, 01:03 GMT-4
Dear Alex
Thanks for your suggestion. This helps me a lot. I was confused for days, now I can have a good sleep. Haha
Yours,
Ming
Dear Alex Thanks for your suggestion. This helps me a lot. I was confused for days, now I can have a good sleep. Haha Yours, Ming
