Edgar J. Kaiser
Certified Consultant
5 years ago
31.05.2020, 03:55 GMT-4
Andrea,
best is to make a model that can be compared to an analytical solution.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Andrea,
Cheers
Edgar
5 years ago
31.05.2020, 18:33 GMT-4
I read that there are limitations of conventional EM simulations when the mistmatch between the wavelength and feature size becomes very large.
If a student said that I would ask where he read that and why the author says it happens.
If you wanted to do a comparison between simulation and analytic solutions, then scattering of a plane wave by a sphere would be a good test problem. The Rayleigh scattering solution is valid in the limit of a very small sphere in relation to wavelength, and the Mie scattering solution is valid for larger spheres.
5 years ago
31.05.2020, 18:39 GMT-4
Thanks for the feedback--I think I have quite a bit more reading to do to understand this issue. I'll check out modeling the simple case of scattering from a sphere, as you mentioned, and compare this the Rayleigh scattering solution to get a better idea of the limitations of the simulation.
