rotating mesh AC/DC Physics question
Hello all
I have modeled with Comsol 4.2 a stator ring with a ring about 4 inches in diameter with 4 rectangles extending into the center of the ring along the x and y axis representing the four coils of a stator. I selected air for inside and around the ring and steel for the ring and the coil rectangles. I then used AC/DC physics module rotating machinery and declared two multi-turn coil domains, where each one got two opposing "coils" rectangles with 560 turns and a current of Imax*exp(-i*phase1) and Imax*exp(-i*phase2) where Imax is 10 amps * sqrt(2) and phase 1 is 0 degrees and phase two is 90 degrees, pi/2. I then added a prescribed rotational velocity and selected the ring and the four coil rectangles for the domains and 15 rps. I then meshed the geometry and tried to solve a time dependent study but it threw up an error saying failed to find consistent initial values. However, when I make the current for the coil rectangles as just Imax, or 10 amps, the study solves just fine.
What can I do to make the solver solve when I have the currents as Imax*exp(-i*phase1) and Imax*exp(-i*phase2)????
Thanks so much for the help.
Stephen
2 Replies Last Post 15.02.2012, 02:21 GMT-5
Posted: 1 decade ago 14.02.2012, 17:57 GMT-5
bump...
bump...
Posted: 1 decade ago 15.02.2012, 02:21 GMT-5
perhaps you will get more replies if you upload the model or a simplified one. I do not find it easy to understand while thinking of complex "constant" currents with a time solver (and not a frequency domain one).
Hi perhaps you will get more replies if you upload the model or a simplified one. I do not find it easy to understand while thinking of complex "constant" currents with a time solver (and not a frequency domain one). -- Good luck Ivar
