Material properties dependent on two parameters
I'm familiar with using say a function to set a material property that is dependent on one variable (i.e., temperature), but how would I go about setting it for two variables? Would I simply write two functions under the same material? Would Comsol then use both functions for its output?
Kind regards,
1 Reply Last Post 11.02.2012, 04:19 GMT-5
Posted: 1 decade ago 11.02.2012, 04:19 GMT-5
I would say as for 1 variable, use a 2 argument entry for your table / interpolation function or analytical function, check the material library, there are materials depending on both T and p
Hi I would say as for 1 variable, use a 2 argument entry for your table / interpolation function or analytical function, check the material library, there are materials depending on both T and p -- Good luck Ivar
