Hello Stanimir Petrov
12.04.2012, 05:32 GMT-4
Same problem over here, did you manage to solve it out??
regards
regards
25.07.2013, 04:09 GMT-4
my first adaptive mesh refinement is still running, for hours now.. and it does not move anymore..
it is a time dependent microwave plasma simulation. It has arrived to 1E-6 seconds in time, but seems to be stucked in an endless loop searching for convergence.
how to debug those situations? how can I follow what this refinement algorithm is doing?
it is not ploting anything.. no convergence, no results during calculation..
update: my model does only one mesh refinement and the n goes to divergence? I must have missed something somewhere? why isn't it remeshing more than one time?
how is comsol reacting to the error indicator? what formula should be used? which values makes the refinement process start?
thank you
lukas
thank you
lukas
30.05.2014, 11:03 GMT-4
according to the support it seems that it is impossible to suppress the output meshes because they are used by the solver to compute a solution which appears obvious. Which is more embarassing is that you can't avoid saving them and that then your computation can slow down and the size of your file increases a lot (in my case I had about 1000 meshes for a size of 6.5Gb, was really slow).
The solutions I found:
lower quality of the mesh
lower threshold for remeshing
less measurement points
But the quality of the solution is then worse.
If you manage to make better than me I am really interested!
Bye
Bye
