Plotting electric fields along plane for MEF coil simulation
I'm relatively new to COMSOL and I'm trying to simulate the electric field created by an AC current within a toroidal coil. I have been able to simulate the B-field in the axisymmetric builder for a standard coil, but I now need to use the 3D builder for future arbitrary coil shapes. My objective for now is to simulate a coil with 1 amp of current at some frequency and observe the electric field values (and also electric field gradient values) along some plane lying above that coil.
I have currently created a coil, put a box around it to represent air, and have run the simulation but it has been running for hours - is there a simpler way to do this?
3 Replies Last Post 17.05.2020, 17:37 GMT-4
Posted: 4 years ago 17.05.2020, 05:53 GMT-4
If you are not interested in capacitive effects in the coil, you may consider to set it up in mf.
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Posted: 4 years ago 17.05.2020, 16:45 GMT-4
If I set it up in mf, how can I view/calculate electric field values?
>If you are not interested in capacitive effects in the coil, you may consider to set it up in mf. If I set it up in mf, how can I view/calculate electric field values?
Posted: 4 years ago 17.05.2020, 17:37 GMT-4
The induced electric field is available in mf. Check the result variables.
Edgar J. Kaiser
www.emphys.com
