Jeff Hiller
COMSOL Employee
4 years ago
14.05.2020, 11:44 GMT-4
Can you attach your mph file, or at least tell us what expression you tried entering?
Jeff Hiller
4 years ago
19.05.2020, 19:34 GMT-4
Updated:
4 years ago
19.05.2020, 20:22 GMT-4
I am trying to provide an equation which looks like the following
![](data:image/png;base64,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)
Can I provide this equation in the global definitions? Or do I need to enter it by defining a PDE using the math module?
Thank you.
R_2 = K \frac {dc_2}{dt}
Thank you.
Jeff Hiller
COMSOL Employee
4 years ago
20.05.2020, 11:18 GMT-4
Updated:
4 years ago
20.05.2020, 18:19 GMT-4
Yes, you should be able to enter an expression like that for your reaction term. The issue is likely one of syntax or scope of the variables involved. In particular, you mention that you are trying to use global definitions, but I doubt that c2 has a global scope, i.e. c2 is, I presume, defined at the Component level in your file.
Jeff Hiller
