Point3 boundary settings!
I am using Comsol 3.5a with matlab, I am creating in graphic interface a Point3 and when I want to set the boundary of that point is imposible to put any. The point is created in a 3D geometry and the 3D geometry is a single entity... for the points of this geometry there is no problem to set values but the extra point created does not give this option. Is it the license? I really appreciate any answer...
1 Reply Last Post 31.01.2012, 08:58 GMT-5
Posted: 1 decade ago 31.01.2012, 08:58 GMT-5
it might be that your point (if I understand you add it to a closed contour) is not considered by COMSOL as belonging to the polyline. You might need to split and combine or convert the polyline + the point into a higher order element. Check the doc, 3.5 is getting old for me ;)
Hi it might be that your point (if I understand you add it to a closed contour) is not considered by COMSOL as belonging to the polyline. You might need to split and combine or convert the polyline + the point into a higher order element. Check the doc, 3.5 is getting old for me ;) -- Good luck Ivar
