4 years ago
16.04.2020, 04:38 GMT-4
For analyses of this type, some solver settings may need changing. Are you running a stationary model? Are you apply a load or a displacement? How are you controlling the ramping of the load?
As a first step, try digging into the solver settings. Right click your Solver Configuration node and choose "show default solver" and under "Stationary Solver - Fully Coupled - Method and Termination" choose Constant (Newton). A little lower down in those same settings is an option to update the Jacobian, choose "on every iteration". A little further down, there is an option to choose a "Stablization and acceleration" setting. Select Anderson acceleration and increase the Dimensions of iteration space to 25.
Those settings have proven ideal for Hyperelastic MR and also Ogden defined materials.
Of course, the settings in the Physics nodes will also need scrutiny, but try the above first if you are confident in the settings you ave in your Physics nodes...
4 years ago
16.04.2020, 06:41 GMT-4
Updated:
4 years ago
17.04.2020, 04:13 GMT-4
Thank you MortalWombatUk
4 years ago
Updated:
4 years ago
4 years ago
05.05.2020, 05:22 GMT-4
Hi, do you have a source where I can find more information on settings like these for hyperlastic material modeling?
I'm also simulating with the Mooney-rivlin model, and can't get the solver to converge.
