Cluster Computing - Solvers and Memory
Posted 23.01.2012, 10:32 GMT-5 Studies & Solvers Version 4.2a 1 Reply
I encountered two problems when trying to run a job off our PBS run linux cluster (using command line approach).
1) The first is regarding the solver. I got the following error:
Warning: PARDISO is not distributed. Switching to MUMPS.
How can I switch the PARDISO solved to distributed? Note that the mesh is very coarse and thus an iterative solver will not be able to find a solution (based on my investigation in a smaller subset of the geometry)
2) My second problem is that I tend to always get one of two memory related messages:
a) Out of memory LU factorization
b) Out of memory in Stationary Solver
Is this related to the RAM? Any advice considering I am stuck using a direct solver at the moment?
Here is the relevant section of the script file submitted:
nn=$(wc -l < $PBS_NODEFILE)
echo "--- mpd BOOT"
comsol -nn ${nn} mpd boot -f $PBS_NODEFILE -mpirsh ssh
echo "--- mpd TRACE"
comsol mpd trace
echo "--- parallel COMSOL RUN"
comsol -nn ${nn} batch -inputfile disttubecoarsepbs2.mph -outputfile disttubecoarsepbs2out.mph -batchlog batch_jan23.log
echo "--- mpd ALLEXIT"
comsol mpd allexit
echo "--- Job finished"
echo "--- mpd BOOT"
comsol mpd trace
comsol mpd allexit
1 Reply Last Post 23.01.2012, 21:23 GMT-5
