Piezoelectric Simulation (pzd) in comsol 4p2 for FBAR filter
There is a parameter in COMSOL 4.2, in piezoelectric simulation, pzd.Y11 which gives you input impedance if you simulate a one port device. I think this correspnds to Y11 parameter of Y matrix. I am simulating a 2 port device (filter) and need to get Y21 and Y11 parameter to be able to calculate S parameters (Y12 and Y11 is not necessary since it is symmetric and reciprocal). I couldnt see pzd.Y21 parameter in the tutorial or help, but when I defined it as variable, it looks it is working if I set the voltage of the terminal 2 as 0 V. When I set the voltage of the second terminal different from 0 V comsol cannot calculate pzd.Y21 parameter, which makes sense to me. I believe that is correct but would like to verify with someone else if anyone tried using such a paramater.
Thanks for the help!
Seyit
2 Replies Last Post 13.12.2013, 12:08 GMT-5
Hello Seyit Sis
Posted: 1 decade ago 20.03.2012, 12:18 GMT-4
I am having the same issue but I don't understand why COMSOL cannot calculate pzd.Y21 when let's say I apply -1 V to terminal 2. I am trying to design a differential filter in a way that I apply Vin+ Vin- for the input ports and get Vout+ and Vout- for the outputs. I was also doing two port designs based on piezoelectric actuation before but was not quite sure if the simulation was correct or not.
To get pzd.Y21 and complete the S matric what should I do? Should I move to RF module?
Serkan
Hi, I am having the same issue but I don't understand why COMSOL cannot calculate pzd.Y21 when let's say I apply -1 V to terminal 2. I am trying to design a differential filter in a way that I apply Vin+ Vin- for the input ports and get Vout+ and Vout- for the outputs. I was also doing two port designs based on piezoelectric actuation before but was not quite sure if the simulation was correct or not. To get pzd.Y21 and complete the S matric what should I do? Should I move to RF module? Thanks, Serkan
Posted: 1 decade ago 13.12.2013, 12:08 GMT-5
Hello Seyit,
I am having the same problem: I would like to do a frequency domain analysis with a two port resonator. I was wondering if you could be a bit more specific on how you defined Y21 on your second port. Did you simply integrate over the surface 2*pi*freq*pzd.nD under global evaluation?
Thank you for bringing this up.
Richard
Hello Seyit, I am having the same problem: I would like to do a frequency domain analysis with a two port resonator. I was wondering if you could be a bit more specific on how you defined Y21 on your second port. Did you simply integrate over the surface 2*pi*freq*pzd.nD under global evaluation? Thank you for bringing this up. Richard
