Explicit specification of damping constant
Posted 21.03.2020, 15:19 GMT-4 Structural & Acoustics, MEMS & Piezoelectric Devices 4 Replies
I am modeling a MEMS resonator in 3D using the structural mechanics physics interface.
Experimentally, the response of the resonator closely follows the classical model of a 1D damped, driven harmonic oscillator. Based on experimental data and physical dimensions, I know the 1D model parameters m, k, and b (mass, spring constant and damping constant).
It was straightforward enough to set up my 3D model in COMSOL to match m and k from experimental data.
Where I am struggling, however, is the damping constant b. For now, I am not interested in calculating b from "first principles": e.g., by adding a physically representative squeeze-film damping condition or considering viscous/thermal losses to the surrounding air.
Rather, I already know b, and I'm looking for a simple way to make my 3D model exhibit the same b that I measure. Is there a surface or volume condition I can apply, or material property I can manipulate, that would make my 3D model exhibit the b that I want? I'm not going for strict physical relevance here, I'm looking for a straightforward and computationally 'easy' way to make my 3D model behave with the b that I specify.
Can this be done? Thank you.
