15.01.2012, 09:33 MEZ
From my understanding, laminar or turbulent flow i.e.SPF is best for flow without hea exchange.
Standard HT is for solids where the object is not moveing (or not significantly) .
While NITF is for fluid + Heat exchange were you have conduction AND convection (mass transfer) with at both significant levels.
But be aware that you add significant complexity to your model, so often its worth to try them out separately, just to get the model up running, per physics, and to get some interesting initial conditions, to be closer to the final value for the final full blow model. Sometimes you might be able to separte the different physics, i.e. flow in small tubes, you might have radial conduction, and axial mass transfer, but insignificant cross terms.
This is an excellent exercicie to get the feeling of heat and flow interactions
