Robert Koslover
Certified Consultant
5 years ago
12.03.2020, 13:16 GMT-4
Yes, that sure doesn't look right.
1. Take a close look at your boundary conditions, especially on the needle!
2. You didn't show the mesh. If it is fairly coarse, and depending on the smoothing used in the plot, that could also be a problem. So if your boundary conditions are correct, take a look at the mesh. Your mesh size near the needle should be much smaller than the needle size. Note that given the size of the rest of your geometry, if you naively used the default mesh setting, then this is almost certainly your problem! You need to specify a fine enough mesh in the vicinity of the needle.
5 years ago
12.03.2020, 16:56 GMT-4
Updated:
5 years ago
12.03.2020, 17:11 GMT-4
Hello Robert,
Thanks a lot for your suggestion. I tried changing the mesh settings and I am getting the desired output now. Thank you so much for the help.
My next step in the problem is to evaluate the electric field contour when some positively charged particles are suspended within metal plates. Can you please guide me which reference model/example I can follow to start this simulation?
Hello Robert,
Robert Koslover
5 years ago
14.03.2020, 21:45 GMT-4
Updated:
5 years ago
You can define a spatial charge density, if you want. Look around in the interface and you'll find the setting for it. :) Now, if you want to do dynamic simulations of particle motion, that's another/different problem.
5 years ago
22.03.2020, 15:22 GMT-4
Dear Robert, I actually want to evaluate the potential field line distribution when positively charged metallic spheres are suspended within metal plates (stationary charge problem). I tried assigning positive charge to metal spheres but the potential distribution afterwards don't look correct. So, can you please suggest an alternative or tell me what mistake I am making in my current approach?
Robert Koslover
5 years ago
22.03.2020, 15:25 GMT-4
I suggest that you upload your model to the forum so that anyone interested in it can see how you have configured it and can offer suggestions.
