Heat transfer in porous media
Mohamadreza Nassajian Moghadam
Hello
I need some guides about heat transfer in porous media. I need to model temperature field incide porous matrix when fluid flow inside porous matrix while I have some heat flux from boundaries. my geometry is simple. it is a axisymetric disk. the fluid flow inside matrix is caused by boundary loads on porous matrix.
to do this simulation first I tried to extract velocity field inside the matrix. first I defined a poroelastic model form structural mechanics. The model is time dependent. In this model I have a porous media in which following appling cyclic loads on porous matrix and defining boundary pressure, it is possible to extracted fluid velocity field in porous media in each time step.
Then to model heat transfer in this porous media I added a new model" heat transfer in porous media" in same simulation.
but I have problem! my quistion is:
1:how to couple these to model. because when I add a new model from model builder it needs to define a new geometry while I need to use the same geometry form model 1 because the should be coupled.
2: how I can couple these two model to have fluid velocity field output from first simulation as a input for second simulation at each time step. because for modeling heat transfer in porous media I should input velocity of fluid. and I want to take it from my poroelastic model.
Thank you for you help
Ps: I didn't find any example for heat transfer in porous media and in user guide there is just a short introduction. is there any example for that especially which forced fluid flow inside matrix which is like my case?!
2 Replies Last Post 02.09.2016, 07:42 GMT-4
Hello Mohamadreza Nassajian Moghadam
Posted: 9 years ago 12.11.2015, 15:00 GMT-5
Hello mohamadreza,
I have the same problem with coupling fluid flow and heat transfer in porous media. Did you figure out how deal with Comsol to model your problem ?
Hello mohamadreza, I have the same problem with coupling fluid flow and heat transfer in porous media. Did you figure out how deal with Comsol to model your problem ?
Posted: 8 years ago 02.09.2016, 07:42 GMT-4
Hi Nassajian and Shayan,
Have you all figured out the problem about the porous media?
Hi Nassajian and Shayan, Have you all figured out the problem about the porous media?
