Error: 7248
I need simulate a turbulent pipe flow in comsol3.5a and the viscosity is not constant.
The viscosity depends on the shear rate and when I try to introduce the expression in Global Expressions as
Visc= m[Pa*s]*(Shear[s]+epsilon)^n and Shear = sqrt(0.5*(4*ur^2+2*(uz+vr)^2+4*vz^2+4*u^2/(r+eps)^2)+eps)
I have the error:
"Error: 7248
Undefined value found.
Exception:
com.femlab.jni.FlNativeException: Undefined value found Solvermodel
Stack trace:
at solvermodel.cpp, row 1837, (Undefined value found in the equation residual vector.
There are 2274 degrees of freedom giving NaN/Inf in the vector for the variable logd
at coordinates: (0.0352288,0.494039), (0.0366644,0.495068), (0.0354093,0.495682), (0.0381,0.496096), (0.0368449,0.496711), ...
There are 2270 degrees of freedom giving NaN/Inf in the vector for the variable logk
at com.femlab.solver.FlSolver.femStatic(Native Method)
at com.femlab.solver.FemStatic.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)"
I don't know what I can do to solve this problem. Someone can help me...
Carla
0 Replies Last Post 22.12.2011, 06:02 GMT-5
Hello Carla Cotas
