TableFeature addColumn does not modify Table
I am trying to create a Result Table in the App Builder using this code:
String tableTag = model.result().table().uniquetag("dott");
TableFeature table = model.result().table().create(tableTag, "Table");
Later, when I got the results I try to add them column by column using this method:
table.addColumns(new String[]{"time"}, extraArray);
table.addColumns(new String[]{""+thickness}, realdata);
Both extraArray and realdata are double[][] according to the reference. But when I display the Table in a resultstable view, the Table is empty (also when I try to get the data with e.g getColumnHeaders the added Columns do not show up)
Is there any reason for this. Where did I make a mistake?
1 Reply Last Post 03.02.2020, 11:49 GMT-5
Lars Dammann COMSOL Employee
Posted: 5 years ago 03.02.2020, 11:49 GMT-5
Updated: 5 years ago 03.02.2020, 11:49 GMT-5
Hi Daniel, looks to me like adding a new column only works if there is already some data in the table. Try this code:
String header = "title";
double[] data = {1.0, 2.0, 3.0};
table.setTableData(transpose(new double[][]{data}));
table.setColumnHeaders(new String[]{header});
table.addColumns(new String[]{header}, transpose(new double[][]{data}));
Best wishes, Lars
Hi Daniel, looks to me like adding a new column only works if there is already some data in the table. Try this code: String tableTag = model.result().table().uniquetag("dott"); TableFeature table = model.result().table().create(tableTag, "Table"); String header = "title"; double[] data = {1.0, 2.0, 3.0}; table.setTableData(transpose(new double[][]{data})); table.setColumnHeaders(new String[]{header}); table.addColumns(new String[]{header}, transpose(new double[][]{data})); Best wishes, Lars
