Global Evaluation Problem
I'm just trying to understand the syntax and procedure for using global variables and I keep running into problems with measuring the displacements. I defined a local variable, a point and a displacement direction. I then referenced this local variable with a global variable so it shows up in the global evaluation list. My global variable is mod1.(local variable). I get an error saying "Failed to Evaluate Variable" meanwhile, the point evaluation works great. Can someone explain what I am missing? The model is attached. Thanks.
1 Reply Last Post 19.12.2011, 02:50 GMT-5
Posted: 1 decade ago 19.12.2011, 02:50 GMT-5
i believe you are getting confused about the local variables (defined as per (x,y,z) position) that needs to be integrated over a boundary (or edge or summed over points) and global variables that are independent of the spatial coordinates
In your case i would rather define an model1.Definition.AveW as aveop1(w) over the top area.
w is the "local variabel" but its a field w(x,y,z) so you need to perform an "intop1(w)/intop1(1)" over the top boundary, this means you are doing a integration_over_area_of(w*dx*dy)/Area to get the average value
Hi i believe you are getting confused about the local variables (defined as per (x,y,z) position) that needs to be integrated over a boundary (or edge or summed over points) and global variables that are independent of the spatial coordinates In your case i would rather define an model1.Definition.AveW as aveop1(w) over the top area. w is the "local variabel" but its a field w(x,y,z) so you need to perform an "intop1(w)/intop1(1)" over the top boundary, this means you are doing a integration_over_area_of(w*dx*dy)/Area to get the average value -- Good luck Ivar
